accord new alarm issues
matadoramerican
Member - Posts: 10
Posted: April 13, 2003 at 3:35 PM / IP Logged
I have been installing a Hornet 554t on my 95 Accord coupe EX for a few hours and have run into some roadblocks.
      Q1: It seems as though the alarm can send signals to the remote but the remote cannot send signals to the alarm. My evidence is that a few times the remote received a vehicle pager mode indicator, but I can't arm or disarm the system or remote start the car and the LED never blinks. I don't know if those are based on a few seperate issues wiring issues or just the remote.
      Q2: (based on the first) Why doesn't the system lock the car when the engine starts, even though it unlocks the car when the engine stops (I've checked the wires, green from alarm goes to ->black&white in the car and blue from the alarm goes to ->orange in the car. This lack of locking is further evidence of the systems lack of "arming" type functions, i.e. not remote starting, not arming, etc.
      Q3: The remote start doesn't even try to come on, i think because the alarm is not and has never been armed. It can't remote start with the system unarmed, can it?
Any help would be greatly appreciated.
Paul
draasch
Gold - Posts: 2,172
Posted: April 13, 2003 at 9:21 PM / IP Logged
Constant 12 volts WHITE IGNITION SWITCH HARNESS(FUSED 50 AMP)
double check your wire hook ups.....
make sure you have them hooked up right.
the red should be 12v
the yellow should be 12 switched...
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE/ SILVER (-) GRAY MOLEX TO RT. OF STEERING COLUMN
Trunk Pin Switch ORANGE (-) AT LIGHT
Parking Lamp RED / BLACK (+) ABOVE DRV KICK-20 PIN BLUE CONN PIN 6
Power Lock BLACK/ WHITE 2 PIN PLUG, TAPED TO WIRING
Power Unlock ORANGE HARN. ABOVE FUSE BOX #201
#201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: April 13, 2003 at 9:37 PM / IP Logged
Hey Paul, have you programmed the alarm CPU to the remote control ?
matadoramerican
Member - Posts: 10
Posted: April 14, 2003 at 2:16 PM / IP Logged
---the red should be 12v ---
---the yellow should be 12 switched... ---
What do you mean 12 switched?
The tech support I called (the company I bought it from) told me the remote didn't need to be programmed.  Though I had noted a remote programming section (which I didn't do well with), I figured that was for additional remotes or something.
Thanks for your replies.
Paul
draasch
Gold - Posts: 2,172
Posted: April 14, 2003 at 2:19 PM / IP Logged
12volt switched means when the key is turned to the "on" position
Good Luck
David
Ace Security
813-376-9778
Tampa
matadoramerican
Member - Posts: 10
Posted: April 16, 2003 at 3:43 PM / IP Logged
Jeff from Velocity Motors,
Can you tell me how to program the remote?
Thanks,
Paul
matadoramerican
Member - Posts: 10
Posted: April 16, 2003 at 4:51 PM / IP Logged
You were right about the red being attached to a switched wire. I hooked it up to the battery and now it works! only thing is that i can only disarm/unlock the doors, when i press arm, it does nothing. I think it is either a problem from when i tried to program the remote myself, i may have changed the code, or something related to why the system wont lock when i start the car, but will unlock when i stop the car. Is there a way to erase everything i may have done to the system, but still keep the remote to the factory setting (which, surprisingly was already programmed to the alarm)?
thanks for the help you've already given me,
Paul
