97 Grand Cherokee w/ keyless entry
Holler
Posted: April 22, 2003 at 12:19 PM / IP Logged
I have a 97 Grand Cherokee w/ keyless entry and I'm having an odd problem with the pwr locks. I have experience on door locking systems (single wire / Positive - Negative, and reverse polarity).
Now my problem...
Thinking this is a typical RP system, I have installed the relays inside (OMG!) the driver's door, and have pulsed the keylock wire to disarm the factory anti-theft. Everything works fine (lock, unlock and disarm) using the aftermarket module, however, only the front and rear doors on the driver side work.
Does anyone have a solution?
Derek
Copper - Posts: 83
Posted: April 22, 2003 at 6:51 PM / IP Logged
I pretty sure you have to do what you did in the drivers door, also in the passenger door.
You could of bought a module (a DEI 455T) to do all this through the data bus, But what your doing will still work.
Holler
Posted: April 22, 2003 at 7:19 PM / IP Logged
Thanks for the tip Derek :)
I will have to go back and grab a couple more relays.
Hmmmm... why would they have to complicate such a simple thing? Any other veichle I have worked on only needed one set.
Hehehhehe... Thanks again 97 Grand Cherokee w/ keyless entry - Last Post -- posted image.
