how to install remote door locks?
skyline_man
Member - Posts: 35
Posted: May 09, 2003 at 10:20 AM / IP Logged
I've got a japanese car that has central locking but only the passenger door has the actuator. The driver's door has no actuator. Now i know that i need to get an extra actuator for the driver's door but do i need to get a control module as well do that i can hook my alarm to it? or is there a way i can connect the driver's door actuator to the factory centrol locking control module? thanks
draasch
Gold - Posts: 2,172
Posted: May 09, 2003 at 12:41 PM / IP Logged
what are you putting in the car???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: May 09, 2003 at 2:30 PM / IP Logged
If you have central door lock system, you only require one actuator to control both doors, either passenger or driver. Doesn't matter. If you trying to hook up a relay circuit to an alarm system to have keyless entry then you will need to have two relays wired up like this diagram.
