using a high/low level converter?
emorse2323
Copper - Posts: 106
Posted: May 16, 2003 at 8:59 AM / IP Logged
IF you use a convertor because of a factory radio what do you use for the remote wire?? Also what is the best to do tap into the front or back speakers?
thanks
bberman1
Gold - Posts: 2,314
Posted: May 16, 2003 at 9:12 AM / IP Logged
For the remote I usually tap into the radios switched 12 volt that turns the factory radio on and off with the ignition. If the car dose not have one then I will find another switched 12 volt source. As far as taping into the front and back speakers it depends on the car. What kind of car are you referring to?
emorse2323
Copper - Posts: 106
Posted: May 16, 2003 at 2:17 PM / IP Logged
The car is a 2003 nissan maxima
