Led light bar wiring
straightshot7
Member - Posts: 9
Posted: December 01, 2015 at 1:43 PM / IP Logged Link to Post Post Reply Quote straightshot7
Need some advice on how I can wire up 2 20 inch led light bars I'll be purchasing for my 2014 Honda Civic si sedan. I'll be running 1 up front and 1 under car in rear for extra reverse light. I want to run 2 3 way rocker switches for both, on/off/on, for front bar I want to be able to come on with high beams on one switch position, then have off completely in middle switch so it won't come on at all, then have in other position independent on whenever I select it? Then reverse light will be same concept, except one position to come on with reverse lights, then off, then independent on.
What's the best way to do this, the harnesses come with relays but not sure if I would need 1 or 2 per bar.
installs plus
Posted: December 22, 2015 at 2:21 AM / IP Logged Link to Post Post Reply Quote installs plus
i know my post is kinda late if this is not done call me i can walk you through this or any other install. Im MECP through NC and can help you with any install question... Names ricky btw over 17 years exp
Wednesday, October 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
