CRX window module
thebase
Member - Posts: 13
Posted: June 24, 2003 at 5:07 PM / IP Logged
Hi guys
I recently ftted a compustar 2wfm alarm and that works fine but now I wnat to hook it up to my windows does anyone have the wiring colours/diagrams it would be helpful .  I tried to do it by gueesing but only manged to get drivers side to go up or passenger side but not together al from the drivers door.  If I am doing it wrong please can someone advise me
Also how can I arm it so when i arm it the windows go up
thanks
There is only one life > The afterlife
SoundImage
Copper - Posts: 75
Posted: June 24, 2003 at 10:27 PM / IP Logged
The best thing to do is to use a multi meter or a test light.  the one that reads voltage when the switch is in the direction you want is the wire.  if you have one touch you'll need to go straight to the driver door window motor to bypass the relay.  to make them go up simply hook it to the armed output wire of the alarm usually orange.  if you have a starter kill relay you may need to isolate with a diode.  good luck
