2003 malibu Passlock2 or 3?
Qveon
Member - Posts: 40
Posted: July 02, 2003 at 1:42 AM / IP Logged
Well? Anything else i should know about when doing a remote start on it? Doorlocks, is there factory security and does it still use a 1500ohm resistor? Thanks
mr12volt
Member - Posts: 28
Posted: July 02, 2003 at 6:14 PM / IP Logged
1500ohm resistor for what?
NowYaKnow
Gold - Posts: 1,217
Posted: July 03, 2003 at 3:53 PM / IP Logged
I really don't feel like looking this up so you probably should..But off the top of my head I'm thinking you need a 470 ohm resistor, and a 555L for the passlock 2..Other than that nothing real tricky..Trunk release is negative @ the switch I think I remember my info saying positive somewhere..
Platinum - Posts: 12,488
Posted: July 03, 2003 at 9:41 PM / IP Logged
Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse. It's a WHITE wire in the driver's kick panel.
