1998 dodge alarm install
moby0906
Member - Posts: 10
Posted: August 06, 2003 at 6:45 AM / IP Logged
Recently purchased a dodge ram 1500 quad cab with power locks.  I am looking to install a keyless entry/alarm system probably a commando 550 system.  Just looking for any advise before I start to tackle this job.  It seem the keyless entry part might tricky.  Any advise or suggestion would be greatly appreciated before I get myslef into trouble.
Thanks in advance
moby
draasch
Gold - Posts: 2,172
Posted: August 06, 2003 at 8:01 AM / IP Logged
Make:   Dodge
Model: Pickup - Fullsize
Year:    1998
This Database Was Last Updated On:    6/9/03
Index #: 344
Alarm
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) 26 PIN CONNECTOR BEHIND DRIVER DASH
Trunk Pin Switch N/A
Parking Lamp BLACK / YELLOW (+) 74 PIN CONNECTOR BEHIND DRIVER DASH
Power Lock ORANGE / VIOLET 10 PIN CONNECTOR IN ACCESS #203
Power Unlock PINK/VIOLET HOLE IN DRIVER KICK PANEL
#203 - See Reversal Rest At Ground Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
moby0906
Member - Posts: 10
Posted: August 06, 2003 at 8:22 AM / IP Logged
thanks david
moby0906
Member - Posts: 10
Posted: August 07, 2003 at 6:14 AM / IP Logged
Is their any other hints or tricks for an install on this type of truck?
thanks
moby
chasesaccessori
Copper - Posts: 198
Posted: August 07, 2003 at 11:56 AM / IP Logged
take the drivers side of the dash(lower part) off. Will give you all kinds of room to work. Removal of the instument bezel will also give you access to room for let and to get to parking light switch easier.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
