Painting Amps
skam213
Member - Posts: 18
Posted: August 09, 2003 at 12:41 PM / IP Logged
i have 4 kenwood excelon amps, 2-201t, 301t, 501f and i want to paint them to match my interior, my question is;  will this allow the proper heat dissapation? the amps all have internal cooling fans,but i want to make sure i don't destroy anything.
you can put a bullet in my head, but you can't kill a word i've said
bberman1
Gold - Posts: 2,314
Posted: August 09, 2003 at 1:45 PM / IP Logged
Maxst
Silver - Posts: 866
Posted: August 09, 2003 at 6:26 PM / IP Logged
go with hi temp paint...like engine block paint. i think a couple cans would do it easy.
I need quality equipment, feel free to donate.
crichols82
Copper - Posts: 83
Posted: August 09, 2003 at 6:47 PM / IP Logged
the kicker kx amps allow you to paint the exterior, and they also produce a reasonable amount of heat....Like what Maxst said, you should be able to use some hi-temp stuff and it would work just fine
skam213
Member - Posts: 18
Posted: August 12, 2003 at 5:45 PM / IP Logged
thanx.
bbmecp
Member - Posts: 12
Posted: August 12, 2003 at 11:58 PM / IP Logged
Just for the record all the heat dissapation occurs internally where the mosfets and other components are pressed onto a large block of metal called the heat sink usually seperated by either hi temp grease or heat pads and then if it produces enough heat it is then spread throughout the amp. So all in all the only reason to use a hi-temp paint would be for chipping or peeling but i have had great luck using plain old automotive paint. not just in a can paint but actual PPG automotive paint i sprayed my JL 1000.1's with and they produce some heat but I am pushing the limits on them.
everyone calls me subwoofer
