Air bag (SRS) light
zmsaad
Member - Posts: 34
Posted: August 26, 2003 at 11:40 AM / IP Logged
Hello guys, I was installing aremote starter in a galant. While I was looking for the lock/unlock wires, I disconnected the air bag terminal connection in the steering wheel area and behind the glove compartment. I think there were very small springs in the connections that I did not know about. Now I have a light in the dashboard says SRS. How can I fix this. Thanks
jaxman
Copper - Posts: 185
Posted: August 26, 2003 at 4:26 PM / IP Logged
Have you tried to take the baterry off and let it like so for 5 minutes ?
Then put the baterry back , start the engine and let it run for 5 minutes.
Then take it for a ride (normal speed) for 5 minutes. Park the car , turn it off and after a minute try turning it on again.
It might help.
jrilla
Gold - Posts: 1,498
Posted: August 26, 2003 at 5:09 PM / IP Logged
Check the fuses.
J Rilla
Owner/Installer
zmsaad
Member - Posts: 34
Posted: August 27, 2003 at 7:15 AM / IP Logged
Thank you for your time, yes I tried the battery and fuses are ok. any other ideas. I trhink there was a small spring like in one of the SRS connectors when I unplugged it.
jaxman
Copper - Posts: 185
Posted: August 27, 2003 at 7:17 AM / IP Logged
Have you tried to contact a car dealer ? He might be able to supply you the spring you are talking about.
