Install hints/trade secrets
pampanga
Member - Posts: 13
Posted: September 08, 2003 at 2:54 PM / IP Logged
Getting ready to do an alarm install (Prestige APS25KB) in a 91' Honda Accord. Any advice, hints, comments, tricks,(things the install guide may not cover). Past problems? 12volt wiring diagram accurate? Thanks!!
Mr.Swifty
Member - Posts: 37
Posted: September 09, 2003 at 2:32 AM / IP Logged
Take your time.....and even though you have a wiring diagram, check to make sure it's correct
Good luck
cpgoose
Gold - Posts: 1,098
Posted: September 09, 2003 at 6:34 AM / IP Logged
Get a couple of diagrams and compare them (use the one on this site, as well as bulldogsecurity, and Design Tech). Check your wires with a meter to double check.
From my experience, don't make the dumb mistake of wrapping wires temporarily to see if it works with putting a quick piece of electrical tape on it. So many times I just wrapped the wires real quick to see if the connection was right, and they moved and hit a ground source, and I would kill a fuse.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
Mr.Swifty
Member - Posts: 37
Posted: September 09, 2003 at 11:10 PM / IP Logged
No need for temporary connections....either it's right or it's not......just be confident in your work
mazdatruckin
Copper - Posts: 69
Posted: September 10, 2003 at 9:52 AM / IP Logged
This car shouldn't be much of a problem. I did my girlfriends 91 accord not too long ago. All wires are accessible and mostly on the left side of the steering wheel. is it a remote starter? No real tricks, just take your time and verify all the wires.
