Tach wire on 98 S-10 Blazer
miked73
Member - Posts: 15
Posted: September 13, 2003 at 1:42 PM / IP Logged
Help, I am trying to locate the tach wire on my Blazer. Is there a better way then using the tach wire for the remote starter? I found a white wire coming off the coil that goes to ground when the vehicle is started but I have never had this much trouble installing a remote starter. Any help is greatly appreciated.
Rox0rz_Carz0rz
Member - Posts: 15
Posted: September 13, 2003 at 2:10 PM / IP Logged
meh, if u can't find the tach wire, just grab a signal off one of the cylinders.
Did Anybody Order A Pizza?
CBates
Copper - Posts: 58
Posted: September 14, 2003 at 6:54 PM / IP Logged
Your looking for a white wire at the powertrain control module. Im going to send you a little tech note for the passlock system. Hope this helps.
