battery backup siren
sordee
Member - Posts: 18
Posted: September 22, 2003 at 1:37 PM / IP Logged
 I have a Fusion battery back up siren (FBBS).  I have no instructions forit. There is four wires  Red, Black, Blue and White.  If anyone has an idea of what wire is what,that would be very helpfull.
Thankyou.
floaterr
Silver - Posts: 383
Posted: September 22, 2003 at 2:53 PM / IP Logged
If the red is fused and no one responds. Here's what I would try.
Connect the red to a constant (sit it on the battery till you finished testing). Negative to ground.
Probe the other 2 wires. One should be putting out 12v the other with go negative (or is it positive?) when the red is disco's.
Should be
red - constant
black - gound
blue - neg output to trigger alm
white - probably to the alm's red wire. (throughput).
auex
Platinum - Posts: 5,041
Posted: September 22, 2003 at 4:24 PM / IP Logged
I would think that the White wire would go to the alarm's siren output.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
tcool
Copper - Posts: 100
Posted: September 23, 2003 at 12:04 PM / IP Logged
I have a similar battery back-up siren that is wired as follows:
Red- +battery constant
Black- -battery constant
White-  + positive siren input from alarm (brown wire on most alarms)
Blue-   - negative siren input from alarm (Most new alarms do not use this)
You can check your alarm instructions and it will tell you whether the siren output is positive ( +) or negative (-)
bzzzzttttt
