Need some wiring help please
JeffReeder
Posted: September 24, 2003 at 1:32 PM / IP Logged
I am in the process of installing a Clarion M3170(AM/FM tapeplayer ) radio in my fishing boat. The head unit has a standard wiring harness. I have located and identified the speaker leads within the harness. My problem lies in the power leads. I know the yellow goes to the +battery term. And black goes to -battery term. Now this leaves 2 more wires... One is red that is tagged 12volt accessory and the other wire is blue w/ a .5amp fuse. Any help on this would be greatly appreciated.
wvsquirrel
Gold - Posts: 1,237
Posted: September 24, 2003 at 1:42 PM / IP Logged
The red one goes to your ignition. That's the one that will not allow the headunit to turn on unless the key is in the ACC or On position. You can hardwire it straight to the battery if you want to listen to the radio w/o the key being in the ignition (make sure to fuse it though). The blue one sounds like a remote lead. You wont need it unless you are using external amps.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
JeffReeder
Posted: September 24, 2003 at 1:49 PM / IP Logged
Squirrel:
Thanks much for the help. What size fuse would you suggest for hard wiring the red wire? And BTW, I'm not going to use an external amp in the boat.
Thanks,
wvsquirrel
Gold - Posts: 1,237
Posted: September 24, 2003 at 2:01 PM / IP Logged
Check your manual, it should have the specific size needed. I'm not the greatest at picking fuse sizes, but I'd say around a 5 - 15 amp inline fuse. Definately get someone else's opinion on that one though.
Squirrel
JeffReeder
Posted: September 24, 2003 at 2:05 PM / IP Logged
I picked this head unit up at a garage sale for $2. That's the problem, NO manual.Need some wiring help please - Last Post -- posted image.
Thanks for the advise though!
Fireman__1
Member - Posts: 11
Posted: September 24, 2003 at 4:38 PM / IP Logged
most radios commonly use a ten (10) amp fuse.
Joshua Hickey
