plxr vats bypass
mainormoscoso
Member - Posts: 41
Posted: October 26, 2003 at 8:29 PM / IP Logged
  I got the PLXR module to bypass the VATS sistem on a 1999 cehvrolet Lumina but the instructions don't tell you how to conect to VATS i got 2 white wires and ths are the instructions that i got:
https://shop.bypasskit.com/OriginalManual/PLXR_010101_I.PDF
I don't see a way to conect this module to a VATS
Platinum - Posts: 12,488
Posted: October 26, 2003 at 9:07 PM / IP Logged
From what I can understand of the PLXR, you would hook up the VATS like the ION. The VATS wire you can use either one of the two and cut onein half and wire it up like the Ion. Call tech support tomorrow and ask for Steve, he will tell you if this is correct or not. Please post your results .
