Adding power locks to 99 GMC
elkie
Member - Posts: 16
Posted: November 11, 2003 at 2:19 PM / IP Logged
Hey all,
  Used your site alot , but first time I ever asked any ?'s.  I have a 99 GMC sierra ext cab truck with manual locks/windows.  I'm wanting to before christmas get at least power locks in the truck.  I see that valiant has a keyless entry system with all parts need for 99 at jcwhitney.   Is that a good brand to chose.
   If not is there any other kits that come with keyless plus parts to due this?
Thanks in advance!!!
Platinum - Posts: 12,488
Posted: November 11, 2003 at 4:13 PM / IP Logged
You can use universal actuators that are the same quality as those on JC Whittney's site for alot less on eBay. All you need to do it get a set of relays and some actuators and the cost would be about $ 15 - 20.
elkie
Member - Posts: 16
Posted: November 11, 2003 at 8:15 PM / IP Logged
thanks for the reply!!
  Is the only place you can get those are at ebay?
  Also how do you hook them up then?   I've know A LOT about electrical and such, but you mention relays and such is there any write up on this?   Can I just get the two actuators from a junk yard?     what do I all need to pick up?  just the actuators, or more?
  thanks for any and all help you give!!
Posted: November 11, 2003 at 9:55 PM / IP Logged
No, you can get them at alomost any place that sells and installs alarms & remote starter's. It's just the cheapest place that I could think of. If you want to have someone install it and have warranty, then go to a shop. eBay doesn't really give you products with warranty unless it's from a reputable business. Hook up 2 relays likethis: http://www.velocitymotorsport.com/images/install_notes/104.jpg
profuse007
Gold - Posts: 2,015
Posted: November 11, 2003 at 11:00 PM / IP Logged
dont get them at junkyards, theyre really expensive, 20-40 bucks. they wont sell the actuator alone, they sell it with the latch.
heres one place to get them
Houston,TX
elkie
Member - Posts: 16
Posted: November 12, 2003 at 8:38 AM / IP Logged
thanks for all the info !!
  And the diagram for the locks,  so i would just need to run the wire from the 30 on the relays over to the pass door for them to work as well.,   How due you hook up a switch to it.  and what time of lock/unlock switch can i use,  just a basic on from radio shack???
elkie
Member - Posts: 16
Posted: November 13, 2003 at 3:05 PM / IP Logged
? on the diagram.   to hooking this up.
  There is always a constant 12 power to the relays.   but there are 2 different (-) to the relays.  one is to lock and the other is to unlock.   How would I wire up some time of switch to that?   I'm kind of confussed on that part.   IWhould I have a switch that had 3 positions on it?   push down would unlock, push up lock. and then a constal middle?  where would i find these switches.
  Also to make this work on the other door would I just need to run wires from replay 30 to each wire on the actuator on the pass door.
  Is there any write up/instructions beside this image on setting these up?
Thanks!!!
