Building Passive crossovers
tray262
Member - Posts: 39
Posted: November 20, 2003 at 9:31 AM / IP Logged
I was hoping to someone chould explain the process of building a passive crossover. And explaing the Pros and cons. Thanks.
EzekialPhoenix
Copper - Posts: 83
Posted: November 20, 2003 at 9:42 AM / IP Logged
Check this page out: http://web.njit.edu/~cas1383/proj/main/  Go to the bottom
I be tossin and flossin, my style is awesome. Causin' more family feuds than Richard Dawson.
auex
Platinum - Posts: 5,041
Posted: November 20, 2003 at 5:32 PM / IP Logged
Pro, you have complete control of crossover points.
Cons, expensive, confusing, can get very large, and generally wastes upto 50 percent of the power put into them.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
DYohn
Platinum - Posts: 10,741
Posted: November 20, 2003 at 6:03 PM / IP Logged
I've been building passive Xovers for many years.  Here's a few other pro/cons:
PRO: Generally a warmer, more natural sound can be achieved; driver inefficiencies can be corrected; complex setups can be easily created (like line arrays or multiple tweeters, etc) without multiple amps; SQ can be created that is far superior to that found in most electronic xovers; any Xover slope or Xover point can be acheived (not just factory pre-sets); does not require 12V power or remote turn-on...
CONS: You REALLY have to know what you're doing to get it right; adjusting Xover points or slopes requires removing and replacing components; can add noise or harshness if low-quality components are used; the Xover can be the limiting factor in system power handling; cannot easily swap drivers or setups without also physically re-buildig the Xover...
That being said, I prefer the sound of passive Xovers and use them in my own setups.  The notion that they can rob 50% of amplifier power is a bit extreme, but they do use some energy that would otherwise be available for the drivers.  Usually about 2% for a properly built Xover network, in my experience.
Get the Loudspeaker Cookbook for a great introduction to designing and building crossovers.
