JBL 300.1 and 2X JL w0
skiflyer45
Member - Posts: 33
Posted: November 30, 2003 at 9:34 PM / IP Logged
I recently bought a jbl bp300.1 to hook up to my 2 12"JL w0's. Anyways....I hooked everything up, however it is just not loud enough. I run a Jensen 300 watt amp before and the jbl is not a single little bit louder, it might even be less.Is there a way to brigdge on this amp......has anybody a similar setup???? Any tips or suggestions??
Thanks in advance
Ketel22
Silver - Posts: 976
Posted: November 30, 2003 at 10:15 PM / IP Logged
whats the current setup? and isnt the amp a mono block?
Quad L Handyman services
skiflyer45
Member - Posts: 33
Posted: November 30, 2003 at 10:19 PM / IP Logged
i have two boxes....ca. 1.2cu each, level and bass boost at full, each sub to one output.
Headunit is a clarion.
I'm not sure if there is another way to wire it? Do you know?
bfog99
Copper - Posts: 212
Posted: November 30, 2003 at 10:33 PM / IP Logged
That is the only way for you to wire it. What if you play with the corss over points?
wvsquirrel
Gold - Posts: 1,237
Posted: November 30, 2003 at 10:46 PM / IP Logged
Deffinately DO NOT attempt a bridge with that amp. It has 2 sets of speaker outputs, but they are really the same channel and are already Internally Bridged.
Try raising the sub level output from the headunit if available.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
skiflyer45
Member - Posts: 33
Posted: November 30, 2003 at 11:15 PM / IP Logged
what are the cross-over points???
