2004 Rav4, Excaliber 1000
BrianB
Member - Posts: 9
Posted: December 06, 2003 at 12:40 PM / IP Logged
Hi,
Anyone have the wiring diagram for the 2004 Rav4? Would also appreciate any words of wisdom, tips, or special findings for this vehicle. I will be installing an Excaliber 1000 on this vehicle next week and appreciate any help that you guys can offer.
Thanks,
Brian
NowYaKnow
Gold - Posts: 1,217
Posted: December 06, 2003 at 1:23 PM / IP Logged
Toyota 2004 Rav4
Battery: White or BLACK/ Red (+) @ Ignition Harness
Ignition 1: Black (+) @ Ignition Harness
Ignition 2: BLACK / YELLOW (+) @ Ignition Harness
Accessory 1: Blue/Red (+) @ Ignition Harness
Starter: Red (+) @ Ignition Harness
Bypass Type: Transponder
Tach: Black - At the ECU behind glovebox pin B27
Speed Sense: Violet/White - Pin B22 @ ECU near front of center console
Parking Lights (+) Green Red @ Fusebox in 11 pin connector
Parking Lights (-) Light Green @ the switch
Brake (+) GREEN / WHITE @ brake switch
Horn - GREEN/ Red (-)
Lock: Blue/White (-) In drivers kick in 16 pin conn.
UnLock: Blue / YELLOW (-) In drivers kick in 16 pin conn. may need a double pulse.
Child Safety: Blue/Red (-) In drivers kick in 16 pin conn.
Door Trigger: RED / Yellow (+) drivers door sill
Haven't done one but that's the info I have should get you started..
Mike
