2001 ford focus remote start
patmar
Copper - Posts: 69
Posted: December 09, 2003 at 8:22 PM / IP Logged
i just finish installing a remote start(autostart as-1414) on a ford focus 01.when the car is run for few minutes he engines sut off en restrat again. e dut off around 800 rpm
ck auto
Copper - Posts: 257
Posted: December 09, 2003 at 8:38 PM / IP Logged
hi did you use a bypass module also go into diagnostics mode after it shuts down  and see why it shut down. don't shut down with remote or brake let it shut down the way it does when it fails.
good luck
kirk
patmar
Copper - Posts: 69
Posted: December 10, 2003 at 8:40 AM / IP Logged
i thing is the tach signal is is not strong after warm up i use black yellow for tach at coil module
Platinum - Posts: 12,488
Posted: December 10, 2003 at 9:07 AM / IP Logged
You should have used the BLACK/ GREEN at the coil and also the Focus has the E-PATS on it to bypass.
patmar
Copper - Posts: 69
Posted: December 10, 2003 at 6:34 PM / IP Logged
yes jeff i'm use BLACK/ green on coil but if engine turn around 800rpm the engine shut off. I,m use the auto learn tach and the light goes off and after 30 sec. go on.do you have the info for use a injector or at ecm
patmar
Copper - Posts: 69
Posted: December 12, 2003 at 6:33 PM / IP Logged
thanks you everyody for your help i,m fix problem. signal from coil is too strong for remote starter use a 10k in line tach wire solve my problem.
thanks
