Can any amp be bridged?
vman
Member - Posts: 32
Posted: December 11, 2003 at 2:23 PM / IP Logged
Hello out there in install land, time for another plea for help. I have an ADS power plate 80 amp, and was wondering if it was possible to bridge it. I have a power plate 40 which has a bridge mode switch, but the 80 does not. Is it a simple matter of "y"-ing the input and using the two positive outputs, or is there more to it than that. Any help would be greatly appreciated.
Durwood
Copper - Posts: 126
Posted: December 11, 2003 at 2:38 PM / IP Logged
There are quite a few stereo amps that simply cannot be bridged.  Oftentimes, this is because the amp has a separate power supply for each channel.  Some of the old PPI amps couldn't be bridged for this reason.
I couldn't find any information on an 80-watt a/d/s Power Plate amplifier.  Is there a model number you could give us, like PH80 or anything like that?
Scott Gardner
vman
Member - Posts: 32
Posted: December 11, 2003 at 3:16 PM / IP Logged
The amp says P80 on the bottom, no other model info. If you have a source for ADS info, I'd love to know what it is. I am installing four of these low power wonders in my Volvo. Thanks for the reply.                                             VM
