2003 monte carlo wiring
bigcoop72
Member - Posts: 20
Posted: January 02, 2004 at 10:42 PM / IP Logged
i need to know the speaker-wire colors from the factory amp to the speakers,so i can bypass the amp.when i use the reverse harness on the input side,the speaker output arent the same configuration.
forbidden
Platinum - Posts: 5,354
Posted: January 02, 2004 at 10:45 PM / IP Logged
Have you found the amp yet?
bigcoop72
Member - Posts: 20
Posted: January 02, 2004 at 10:56 PM / IP Logged
its in the trunk,between the 6x9's.i need the output wire colors to each speaker. i have the 6 speaker system.components in front 6x9 in the rear
bigcoop72
Member - Posts: 20
Posted: January 02, 2004 at 11:43 PM / IP Logged
anyone else know ?2003 monte carlo wiring - Last Post -- posted image.
bigcoop72
Member - Posts: 20
Posted: January 03, 2004 at 8:02 PM / IP Logged
forbidden ,do you know the colors?
