2001 Ford Ranger remote start
p71-cruiser
Member - Posts: 47
Posted: January 12, 2004 at 4:49 PM / IP Logged
Does anyone know of a place that sells a t-harness that is not out of stock?2001 Ford Ranger remote start - Page 2 - Last Post -- posted image.
I need one for a 01 ford ranger (FD-1)
p71-cruiser
p71-cruiser
Member - Posts: 47
Posted: January 14, 2004 at 9:41 PM / IP Logged
I'm installing a remote start on a 2001 Ford Ranger and I'm having a problem with the loop that goes around the ignition switch.
Where is the best place to put this loop for the transponder I see a wire that goes around the ignition switch with blue clips  and that's where I put the transponder wire but it does not want to stay on there close enough to get the range that is needed to send the siginal to the trucks wire.
Also every time I put back the cover on the truck's steering colum The loop gets all messed up somehow and it does not transimtt the key code to the truck so the truck can start
Thank you for any help
p71-cruiser
p71-cruiser
Member - Posts: 47
Posted: January 14, 2004 at 9:46 PM / IP Logged
Can you put the 12v+ power wire from the Rs on to the wire for the truck's starter power hot all of the times (01ranger)?
Where is the best place to put this Rs module on my 2001 ford ranger where it will fit? It's one of those long Rs modules
p71-cruiser
ck auto
Copper - Posts: 257
Posted: January 14, 2004 at 10:39 PM / IP Logged
hi zip tie it in place to hold or even us electrical tape too hold it rioght were you want as a last resort hot glue a dab to hold it just dont get it on any moving parts
good luck
kirk
boomer_106
Silver - Posts: 710
Posted: January 14, 2004 at 11:25 PM / IP Logged
This will tell you where to hook your wires up and what color. Put the module wherever you can fit it but, keep in mind you want the antenna wire as high as possible. Im not familiar with this unit so I dont know if it has the windshield type antenna or not.
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED / L BLUE
IGNITION SWITCH HARNESS
Ignition #1:
L GREEN/ PURPLE
IGNITION SWITCH HARNESS*
Ignition #2:
GRAY / YELLOW
IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3:
2ND GRAY / YELLOW
IGN. SW. HARN. (BLOWER & AIRBAG)
Accessory:
BLACK/ L GREEN
Brake Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
TAN / YELLOW
AT POWERTRAIN CONTROL MODULE**
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH (W/O OEM ALARM) ***
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
D GREEN/ PURPLE (-)
DRIVER KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
*1998 Vehicles May Be Equipped With Ford's PATS Anti-Theft System. **Powertrain Control Module Located On Passenger Rear Of Engine.
Ford
Ranger
1996-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
YELLOW (4)
Starter Kill:
RED / L BLUE
Ignition +12 Volts:
L GREEN/ PURPLE
Dome Lights/Superv:
BLACK/ L BLUE (+)
# PIN CONNECTOR BEHIND DRIVER DASH
OEM Horn:
YELLOW /GREEN (-)
STEERING COLUMN HARNESS
Power Lock:
PINK / YELLOW
# PIN IN DRIVER'S KICK PANEL
Power Unlock:
PINK/L GREEN
Trunk Release:
N/A
Alarm Input Wire:
BLACK/ L BLUE (+)
Notes:
***With OEM Alarm Parking Lights Are WHITE/ BLACK (+) At Headlight Switch.
p71-cruiser
Member - Posts: 47
Posted: January 15, 2004 at 12:20 AM / IP Logged
instead of hooking the RS into the battery for power can I hook it up to the ranger's" yellow constant +12 volts wire?
Also the RS wants a relay to the horn of the truck but can I just put it to the YELLOW /GREEN (-) wire so the RS will activate the truck's horn relay(will I be on the right side of the horn's relay)?
Will I need to tie into the clutch wires for the Remote start to work or does the RS bypass this system somehow allowing the truck to start without the clutch pedal pushed in?
Thanks for the previous info I needed the horn wire
thanks again
p71-cruiser
daniel2002p
Silver - Posts: 524
Posted: January 15, 2004 at 7:24 AM / IP Logged
why are you suing a 555u to do the install, use a 555f and no loop is needed.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
