1997 crystler town&country mini van
p01110101
Member - Posts: 43
Posted: February 04, 2004 at 9:51 PM / IP Logged
wire diagram for the above car
boomer_106
Silver - Posts: 710
Posted: February 05, 2004 at 3:22 PM / IP Logged
Chrysler
Town & Country (Van)
1996-2000
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
D BLUE
Ignition #2:
DARK GREEN/ RED
IGN. SW.HARN.(TRANS CONTROL MOD.) **
Ignition  #3:
N/A
Accessory:
BLACK/ WHITEORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Brake  Light:
WHITE/ TAN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GRAY & D BLUE/TAN
AT POWERTRAIN CONTROL MODULE (2.4L) *
Parking Lights:
BLACK / YELLOW (+)
GRAY # PIN CONNECTOR AT FUSE BLOCK
Headlights:
L GREEN/ ORANGE (-)
AT HEADLDIGHT SWITCH
OEM Alarm  Disarm:
WHITE/ RED (-)
BLACK # PIN CONNECTOR
OEM Alarm  Arm:
WHITE/ RED (-)
IN DRIVER'S KICK PANEL *****
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Each Wire Listed Above Is A 2 Cylinder Signal. 3.0L Tach Wire Is GRAY/RED At Powertrain Control Module (PCM). 3.3L & 3.8L Tach Wire Is GRAY/RED, DARK BLUE/TAN And RED / YELLOW At PCM (Each Wire Is A 2 Cylinder Signal). ** This Wire May Not Be Present And Therefore Is Not Necessary.
Chrysler
1996-2000
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK, RED & PINK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
D BLUE
Dome  Lights/Superv:
BROWN / L GREEN (-)
GRAY # PIN CONNECTOR @ FUSE BLOCK ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ DK. GREEN
Power  Unlock:
SINGLE WIRE SYSTEM
Trunk  Release:
N/A
Alarm  Input Wire:
BROWN / L GREEN (-)
Notes:
**** See Note #211 - Chyrsler/Dodge Mini Van Single Wire Door Locks Diagram. ***** Wire Located at BCM in Connector Closest to the Kick Panel; A Negative Pulse Through A 665 Ohm ResistorDisarm and Unlock the Doors and A Negative Pulse Through A 4020 Ohm Resistor Will Arm and Lock the Doors.
