Viper 790XV Warning Chirp
Budweiser8jr
Member - Posts: 8
Posted: February 09, 2004 at 11:58 AM / IP Logged
I had to turn it all the way up because it is on a wire bundle (huge shock absorber) I will turn it down again once I get it mounted to something solid on the car, but this is the only way it works for the time being. Also, I think I was making this loop thing harder than it should be...I just have to reverse the harness on the shock sensor, correct? Meaning the loop end must be plugged into the brain right now and I need to reverse the ends??
