need help interpreting this pic (relay d
95Legend
Member - Posts: 24
Posted: February 09, 2004 at 2:53 PM / IP Logged
need help interpreting this pic (relay d - Last Post -- posted image.
bigger pic
Im confused as to where 87a and 30 go, both to ground????. Also im not sure what to hook 86 up to i think it says "Negitice input from remote strat, light flash, neg out when remote starts" but the first and the last things it mentions would be two different wires???? can someone help me out
Platinum - Posts: 12,488
Posted: February 09, 2004 at 3:36 PM / IP Logged
When adding a remote start interrupt the BLACK/ red wire in the drivers kick harness to the rear of the vehicle with the status output ( 2nd IGN or 3rd IGN output ) of the remote start. This will keep the steering wheel from moving into place until the key is in the ignition and the brake pedal is pressed.
95Legend
Member - Posts: 24
Posted: February 09, 2004 at 5:54 PM / IP Logged
im not sure what you are telling me because once the car is started with the remote start(started without the key in ignition) the steering wheel memory is automatically erased. I need to add this relay to give the steering wheel power while it is being started so the memory is not erased.
Posted: February 11, 2004 at 3:09 PM / IP Logged
Send me the LARGER file to : velocity@valleycable.com and I will interpret it for you.
