Porsche Remote Start Problem
nevek
Member - Posts: 22
Posted: February 11, 2004 at 5:01 PM / IP Logged
The car is a 1989 Porsche Carrera 4
Anyway it is trying to start but just turns over, almost like it is not getting fuel. I am thinking an iginition wire, but I allready have 2 hooked up, the only other wire is a Grey one coming from the ignition harness. It reads Positive 12v at idle, but when ignition is on it loses its 12v. Does anyone know the solution or how to hook up to this wire if necessary.
Thanks in advance
Kevin
Platinum - Posts: 12,488
Posted: February 11, 2004 at 6:53 PM / IP Logged
What wire did you use for the tach signal ?
nevek
Member - Posts: 22
Posted: February 11, 2004 at 7:02 PM / IP Logged
I got the correct tach wire, but it is running off of alternator mode.
Posted: February 11, 2004 at 7:17 PM / IP Logged
There's your problem. How does the unit know that the car is running if the CPU is switched over to alternator mode when there's nothing attached to it ??
nevek
Member - Posts: 22
Posted: February 14, 2004 at 10:27 AM / IP Logged
what needs to be attached to it?
