This Thing Is Driving Me Crazy
Gentleman
Copper - Posts: 71
Posted: August 11, 2002 at 5:50 PM / IP Logged
Dodge Dakota 2002....Crimestopper CS2000
The door negative trigger was wired to the dome light circuit which has a fade off delay, this caused the alarm to chirp 3 times telling me there is a zone fault and also the delay was preventing the doors from locking because the cpu thought the door was open, other than that everything worked I found in the drivers kick panel a tan wire for the passsenger door trigger and a tan/red wire for the passenger door, these triggers are actually for the door ajar light they are - when doors are open and read nothing when doors are closed, thought I was on to something, used the diode method to wire the two to the alarm. now 30 sec after being armed the alarm goes off. Why ??????
cdaw
Member - Posts: 22
Posted: August 11, 2002 at 11:01 PM / IP Logged
I used a diode - and connected directly to the ajar light wire, behind my dash, this way  (for my car) the trunk is also picked up (along with all 4 doors) w/o needed an extra sensor or wires.
Before, The alrm would not sense the Trunk, and would go off when you closed it, due to the shock sensor. Now - I pop the trunk the alarm wont arm untill 30 seconds after I close it.
I'm using full active alarm./ locks /windows
JT
jt
Gentleman
Copper - Posts: 71
Posted: August 12, 2002 at 5:11 AM / IP Logged
I used the diodes
