How to fit a sub onto a Sony xr-4800 unit
Harvi21
Member - Posts: 12
Posted: March 04, 2004 at 7:01 AM / IP Logged
sorry, they r:    5 inch diameter. Rated Power each 25W, PEAK Power each 140W lol and theres me thinkin they where 10inch How to fit a sub onto a Sony xr-4800 unit - Page 2 - Last Post -- posted image.
well th@s them, i'm just lookin 4 a model number 4 u but i thinkin the amp i must get had 2 be 6 channel if i want 2 power all the speakers, e.g the above 4 and the sub (bridge 2 channels for the sub) or a 4 channel to power the 2 rear speakers and the sub (again bridge 2 channels for the sub)
plz tell me if i'm wrong, th@s just my thinkin from what i've read up on, and the watts per channel is another problem 4 me How to fit a sub onto a Sony xr-4800 unit - Page 2 - Last Post -- posted image.
bryceyaworsky
Copper - Posts: 152
Posted: March 04, 2004 at 7:35 AM / IP Logged
ok, so once again you've lead me astray.  Those 5" speakers can be run from your deck, so all you need is one amp for the sub.  You still need to find out if you can just splice into the rear outputs or if you'll need to use them entirely for the LOC.  My guess is that you would experience some signal loss if you did splice and used the rear deck outputs for the LOC and the 5" speakers.
Something else to consider is your deck.  If it doesn't have RCA outs it probably doesn't have a remote turn-on.  This can be overcome by splicing into an accessory wire from your car and running that to the amp's remote input.
Harvi21
Member - Posts: 12
Posted: March 04, 2004 at 7:41 AM / IP Logged
thanx for th@, the speakers r these ones:    http://products.sony.co.uk/productdetail.asp?id=3_30_2475
bryceyaworsky
Copper - Posts: 152
Posted: March 04, 2004 at 8:10 AM / IP Logged
right, those are the ones that you would typically use with your deck.  Hopefully someone else will be able to clarify the LOC issue so you can get started on your upgrade.  Good luck, and I'm sorry I couldn't be of much help.
Harvi21
Member - Posts: 12
Posted: March 04, 2004 at 8:13 AM / IP Logged
thanx 4 takin time 2 help me out and put me on a right track How to fit a sub onto a Sony xr-4800 unit - Page 2 - Last Post -- posted image.
Harvi21
Member - Posts: 12
Posted: March 05, 2004 at 5:07 PM / IP Logged
hey ppl i still need help here, plz if ne1 can help me, plz post up on here
thank you
