Kicker 12 L5 What amp? How much Watts?
kickerl5
Posted: March 11, 2004 at 3:13 PM / IP Logged
i have a kicker 12" L5... I was just wondering how much watts i could run.. What the best amp would be to use..  I was thinking of a kicker 700 watt mono amplifier.. Would that be good..  Whats a good amp with the right wattage for my subs that is not too expensive but would make the sub slam hard..  Thanks alot
kickerl5
Kicker 12" L5
Rockford 300s Amplifier
bfog99
Copper - Posts: 212
Posted: March 11, 2004 at 11:35 PM / IP Logged
there are a lot of amps that would work. I would look for an amp that puts out no more then 700 watts RMS. One that I like is the JBL BP600.1. I also know the rockford fosgate makes a few that would work.
bryceyaworsky
Copper - Posts: 152
Posted: March 12, 2004 at 7:06 AM / IP Logged
The 12" L5 can handle 600 rms.  If you match it with kicker's KX600.1, you should be happy since it puts out 600 rms.
94bonny
Copper - Posts: 108
Posted: March 12, 2004 at 8:59 AM / IP Logged
i would also go for a jbl 600.1 amp, it will go nicely with your L5 12"
Alpine cda 9813
jl 500/1
eclipse aluminum 15"
kickerl5
Posted: March 12, 2004 at 9:06 AM / IP Logged
Hey thanks to all you guys.. I really appreciate the help... Now i have one more question.. Im kind of leaning more towards the JBL BP600.1 cause i looked up the specs and really like it and its a little cheaper too... But out of tyhe two what do you think would make the combo work better...
JBL BP600.1
Kicker KX600.1
kickerl5
Kicker 12" L5
kickerl5
JBL BP600.1
Kicker KX600.1
Which one do you think will work better..
kickerl5
Kicker 12" L5
