Suggested Amp and Wattage
ampman
Member - Posts: 34
Posted: March 25, 2004 at 6:28 PM / IP Logged
Hi. I was wanting to know what amp you recomend for one 15 inch, 1000 watt/ 500 watt rms, Eclipse, subwoofer. Also what is the recommended wattage(max and rms) for an amp for this speaker, and what would be your advice for an amp other then the one you suggest, that would be cheaper but still perform well.
ampman
Member - Posts: 34
Posted: March 25, 2004 at 6:42 PM / IP Logged
Does in make a difference in quality and loudness if you by a cheap amp instead of an expensive amp?
Ketel22
Silver - Posts: 976
Posted: March 25, 2004 at 7:15 PM / IP Logged
which model eclipse is it?
Quad L Handyman services
forbidden
Platinum - Posts: 5,354
Posted: March 25, 2004 at 7:19 PM / IP Logged
It's an aluminum but is it a svc or dvc?
100,000watts
Posted: March 25, 2004 at 7:27 PM / IP Logged
Its a dvc
88 caddy
One 15 inch Eclipse sub.
rattles my trunk and the car next to me!
ampman
Member - Posts: 34
Posted: March 25, 2004 at 7:31 PM / IP Logged
Yeah, its a dvc
forbidden
Posted: March 25, 2004 at 7:39 PM / IP Logged
A mono sub amp that produces 500 w rms at 2 ohm mono, preferablt at 12 volts.  There are a pile of amps that will do this, here are a couple of decent amps to consider.
Concept CA525 or old model CC500M (new one kicks a$$)
Rockford BD501
Alpine Guy
Platinum - Posts: 2,478
Posted: March 25, 2004 at 7:55 PM / IP Logged
alpine mrd-m500
Sobe_Death
Copper - Posts: 78
Posted: March 27, 2004 at 12:43 AM / IP Logged
try checking out Xtant, my ex GF had an eclipse aluminum 10 hooked to an Xtant amp and that thing pounded harder than ive ever heard one of those subs perform!
superstreet786
Silver - Posts: 339
Posted: March 31, 2004 at 12:29 PM / IP Logged
id get a tad bit higher than 500RMS amp, it wont work your amp as hard at high volumes
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
