gm remotes
Legrones
Copper - Posts: 75
Posted: April 04, 2004 at 1:00 AM / IP Logged
i was asked buy a guy can he have a remote start hooked to his car with out having new remotes and just use the oem ones. so i am asking can u i waould say yes but the only thing would u use like the the lock button to start it or what it has a lock/unlock/trunk.....that is all the buttons.And i think i saw on tv a guy pushed the lock and unlock button and it started so does the factory remotes have a free channel to start a car ?
Dale / Cory
FullForce
Copper - Posts: 103
Posted: April 04, 2004 at 7:38 AM / IP Logged
not really a free channel but i think hitting the lock button twice withing 2 seconds will give the start brain the signal it needs ... only problem is the range on factory setups is not very far which kinda defeats the purpose of remote start
bmf1000d
Silver - Posts: 345
Posted: April 04, 2004 at 4:29 PM / IP Logged
You can hook up a RS to and OEM alarm but like stated before what is the point. The new chev malibu come with the option to have a OEM RS on them. IT would be alot of work you could tap into the factory antenna and replace it with and aftermarket one but thats alot of time and work that you can have done in about 3 hours for a whole new alarm RS.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Legrones
Copper - Posts: 75
Posted: April 04, 2004 at 6:11 PM / IP Logged
thanks for the info sounds good
Dale / Cory
