chambered or single?
eeh1025
Copper - Posts: 113
Posted: April 04, 2004 at 8:19 PM / IP Logged
hey guys question about making a cuztom box what is better if i chamber the 3 subs into there own chamber or can i just make the box one big chamber, does it make a difference or will the chambered be better then 1 big chamber. thanks alot
Ernie
speedwayaudio1
Silver - Posts: 879
Posted: April 04, 2004 at 8:36 PM / IP Logged
make a box with 3 chambers. You can make a single chamber ,but it is unsafe for your subs. Plus it makes the box stronger so it will not flex when the subs hit. Good luck with your project.
Big Dave
Clean Install
Silver - Posts: 446
Posted: April 04, 2004 at 9:04 PM / IP Logged
yes good luck and I would build the box with chambers
If we learn from each success and
each failure, then we can improve ourselves
forbidden
Platinum - Posts: 5,354
Posted: April 05, 2004 at 1:00 PM / IP Logged
Is the amp a mono amplifier? If so I would build it as a coupled chamber knowing this before hand. A coupled chamber usually is slightly smaller. It still needs to have adequate bracing internally to keep the walls from flexing. If you have a sub fail, then the whole works is dead. (Screw on panel to cover holes in brace solves this problem). The safest bet is to build separate chamebrs, but it is not always 100% necessary.
DYohn
Platinum - Posts: 10,741
Posted: April 05, 2004 at 1:37 PM / IP Logged
I always recomend seperate chambers for subs especially in sealed systems, as the physical differences between subs can cause cancellations in a shared enclosure space.  It is safer, sounds better, and it's more flexible, even if, like Rob sugegsts, the overall enclosure size must be larger.
sam1
Copper - Posts: 151
Posted: April 05, 2004 at 3:09 PM / IP Logged
i agree.  in my experience so far chambered has always sounded better.
