amplifier light, protection mode
DYohn
Platinum - Posts: 10,741
Posted: April 15, 2004 at 7:53 PM / IP Logged
One of those subs or two?
JustDoIt2
Copper - Posts: 98
Posted: April 15, 2004 at 8:14 PM / IP Logged
The subs are working fine because i checked with another amp, I opened the other amp and i see some Resistors blown, Where could i but some resistor... to replace,.....
DYohn
Posted: April 15, 2004 at 8:35 PM / IP Logged
You won't answer the question, will you?  Two of those subs in parallel places a ONE-OHM load on the amp.  Bazooka amps cannot handle a one-ohm load and indeed, they will fail.  If you have two 4-ohm DVC subs, all connected in parallel, that's whay your amp fried.  And no, you can't just replace resisters you think are burned and expect the amp to function unless you know what you are doing, sorry.
JustDoIt2
Copper - Posts: 98
Posted: April 15, 2004 at 9:48 PM / IP Logged
Look, the way it was connect it was like this, I have two bazooka amps one to each subs, My subs are dual 4 ohms, (so It means that i can be wired to 2 ohms or 8 ohms right?  they way i did it was for 2 ohms...each one
DYohn
Posted: April 16, 2004 at 8:18 AM / IP Logged
OK, but you never said that before.  Posting complete information is vry important if you really want help.  So ONE of your amps blew, right?  It was either defective or you over-drove it, it sounds to me.  It will need to be repaired by a factory service center.
JustDoIt2
Copper - Posts: 98
Posted: April 16, 2004 at 9:42 AM / IP Logged
yes that was i wa thinking..  thank you for your help///
