Subwoofer Box noise
sk8ingsmurf
Copper - Posts: 198
Posted: April 22, 2004 at 11:28 PM / IP Logged
OK I've had this problem before when I wired a friend's system and now its happening on my own, I have no idea what to do.
When I installed his stuff me and my dad built a custom box to fit just right in his trunk it housed to alpine 12" type r's, when we got it all hooked up it sounded horrible, it was really shaky and rattling like mad.  I tried numerous things, different crossover settings, rerunning wires, even a different hu, but nothing worked.  I blamed it on the subs and assumed I got a bad product (which seemed too coincidental to get two subs with blown voice coils from such a great name).  Time passed and now Im installing my stuff,  me and my dad once again built two boxes to house 2 12" punch hx2's (2 ohm) running off of a 1001bd.  I hooked everything up tonight and I got the same problem, I know there is no way I got bad fosgate and alpine products, I know there is something Im doing wrong with the boxes.  The boxes I have are very small but exact cu match for the hx2s, the type r box was bigger but braced in the middle, we used 3/4 mdf, and caulked all air leaks.  The rattling sounds almost like a blown voice coil but I cant seem to figure out what we could be doing wrong
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: April 23, 2004 at 1:22 AM / IP Logged
If your voice coils were blown, the sub wouldn't move.  My first guess is that your gains are turned up too high, and/or you have a bass boost turned up too high.  If so, then your amp is most likely clipping the signal, creating that horrible noise.  Turn off any bass boost, and turn your gains almost all the way down and see if it sounds better.  If it does, set the gains correctly.
If not, then it is probably your enclosure is the wrong size.  For optimum performance, a subwoofer needs a certain size enclosure.  What size is the enclosure you are using?
Steven Kephart
Adire Audio
aggie altima
Silver - Posts: 298
Posted: April 23, 2004 at 1:24 AM / IP Logged
Are you sure the joints are completely sealed together? I have that problem with one of my boxes and I found out there is a part where there is a really small gap, so the wood is vibrating against each other, causing a really loud vibrating noise. I thought it was my speaker too, but I'm really glad I was wrong. I'm gonna fill it in with some wood glue mixed with sawdust and maybe try to screw it tighter. So yeah, even though there aren't air leaks, there may still be space for the wood to vibrate.
Jon
Don't like rockford subs? Then don't look at my car =)
speedwayaudio1
Silver - Posts: 879
Posted: April 23, 2004 at 3:49 AM / IP Logged
Double check your speaker wires. I had a customer who added some more speaker wire to my install so he could move the box around and he crossed up the pos and neg on a mono amp. sounded like crap he said the subs went bad or the amp went bad. he did not tell me he added speaker wire( and it was not even speaker wire it was a power cord from a toaster) then I spotted his splice and fixed the problem.
Big Dave
sk8ingsmurf
Copper - Posts: 198
Posted: April 23, 2004 at 7:50 AM / IP Logged
Thanks for the help you guys, I am going to check the joints this afternoon.  To be completely honest I didnt screw them together because its a complicated box with weird joints and angles and I had heard I didnt have to.  My dad always tells me wood glue would be better because its so strong (hes a carpentry lover who is used to his old 200 watt 8 ohm system from the 70s, doesnt know how much a 2000 watt max system can pound I guess).  I am not running it off of my 1001bd right now though its back at the place of purchase on a warranty return, Im borrowing a 401s from my friend and have the bass boost up half way, although he did turn the gains up pretty high and I never took the time to turn them down for a couple of days of use, figured I would just leave the bass boost down below its limit.  So I dont think its the gains/boost, I think its probably the wood vibrating Ill screw all my joints together and try to hold it nice and tight.  Thanks again
stevdart
Platinum - Posts: 5,816
Posted: April 23, 2004 at 8:08 AM / IP Logged
i know...if we had felt the ground rumble in the 70's we would have dove for the cellar!
You might not need that bass boost at all.  Halfway is pretty high.  Take the time to set the gains on that amp, even if its being used for just one hour.  It's your speakers that are taking the punishment.
DYohn
Platinum - Posts: 10,741
Posted: April 23, 2004 at 8:27 AM / IP Logged
It is most likely a clipping amplifier from incorrect gain setting and/or bass boost, just like Mr. Kephart originally suggested.  You can't just slap an amplifier in and not "take the time to turn them down for a couple days use."  You MUST set the gain to match the head unit or whatever is driving the amp, and re-set it anytime anything in the signal path changes, and turn off that stupid bass boost system.  Fix this and set it up correctly unless you don't mind buying new subs or amps soon.  Also, while I agree with your dad in general that wood glue is strong stuff, your enclosure will not last if it is simply glued together.  Get out the drill and screw together all your joints, and make sure the seams are sealed with RTV or some other sealant and that the loudspeakerrs are sealed into the enclosure as well.
Thedfndent
Member - Posts: 31
Posted: April 23, 2004 at 9:26 AM / IP Logged
     It seems like a lot of people are under the impression that the gain knob is simply a secondary volume control.  This couldn't be farther from true.
  It's very important to the sound quality of your system that the gain on the amp is set to match the output signal from your headunit.  If it's set too high you'll just have a bunch of noise.  If it's too low then your amp isn't getting enough signal.
2 12" L7's
PPI PCX-1500
4 6.5" Pioneer 4-way's
Kenwood KAC-6401
Lanzar Opti-Drive Cap
Sony CDX-F7700 Headunit
sam1
Copper - Posts: 151
Posted: April 23, 2004 at 4:41 PM / IP Logged
i agree.  use some screws and tune your amp.  when i first got into audio, i didnt know anything except very basic electronics.  all iknew was that when i turned the gain up it got louder, so ikept it that way.  2 amps later and who knows how many woofers, i can tell you that with the gains set properly itll be much louder, precise, and clearer.  take the time to tune it right and youll be amazed.  but anyways, if you really want to know why its that way and learn more, check this site out.  i refer everybody to it.  http://www.bcae1.com/
