95 Deville Trunk issue
golfnut64
Copper - Posts: 80
Posted: April 28, 2004 at 4:55 PM / IP Logged
Hi guys after hooking up the RS in this i find the trunk release switch on the dash does not work. It works with the new remote. When checking the wires at this switch i had a spark & thought i blew a fuse but checked all of them with no luck . There is a disconect switch in the glove box & that seems to be OK also ???   Any ideas ???      Thanks Lloyd
Lloyd
draasch
Gold - Posts: 2,172
Posted: April 28, 2004 at 9:06 PM / IP Logged
Trunk Release YELLOW (-) AT TRUNK RELEASE SWITCH #230
http://wiringinstructions.com/230.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
ranquist
Member - Posts: 36
Posted: April 29, 2004 at 1:12 PM / IP Logged
did it work before,does the key have to be in the on position in order for the trunk button to work?
golfnut64
Copper - Posts: 80
Posted: May 01, 2004 at 5:40 AM / IP Logged
Yes the key has to be on for it to work & it did work before , The switch in the glove box disables the switch on the dash so you can lock it when leaving the key in a parking lot Thanks
Lloyd
