Wiring Info for 93 Caravan Cassette Deck
Seaton663
Posted: April 29, 2004 at 2:11 AM / IP Logged
 I'm looking for a wiring diagram for a radio that came out of my 93 Dodge Caravan.
This is a Mopar Model # 82300002 AM/FM Cassette Deck.  It has two wiring harnesses plugged into the back, one is black and one is gray.  I just want to know what each of these wires is for:
BLACK HARNESS
GREEN/ Red
BROWN / Yellow
BLACK/ White
Solid Green
Solid Purple
Light Blue/Brown
Blue/Orange
GREY HARNESS
BROWN / Red
Blue/Red
BLACK / YELLOW
ORANGE / White
RED / White
Solid Pink
If you could tell me which of these are speaker wires and which are power wires/ground, I would greatly appreciate it.  (I think the the radio is grounded through the antenna).  Thanks!
- Steven Eaton
Seaton663@yahoo.com
- Steven
kgerry
Platinum - Posts: 3,455
Posted: April 29, 2004 at 11:33 AM / IP Logged
you can buy the Metra plug 71-1817 that will plug right into that radio and all the wiring will be EIA
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sonicsound
Copper - Posts: 100
Posted: April 29, 2004 at 11:42 AM / IP Logged
yes, or you can go to Circuit city and by the MET 80-1817 and then buy the smart harness for the HU that you are putting in
Sonic
Pioneer AVH-P4000DVD
Zapco 360.4
Zapco 500.1
Zapco SP-4SL Processor
Two JL 10 W3v3d2
Alumapro 15 Farad Cap
Seaton663
Posted: May 04, 2004 at 1:46 AM / IP Logged
I'm wiring this radio into a different vehicle, and I didn't want to have to go and buy another plug.  I've already got the wires stripped coming out of the harness, and the wires in the new vehicle stripped that will be going into the cassette I'm trying to wire.  All I need to know is which wire is which :)
- Steven
Sweekster
Silver - Posts: 481
Posted: May 04, 2004 at 12:06 PM / IP Logged
So you've cut the wires on the other car already? To make it easier on yourself you could have just gotten an aftermarket wiring adapter harness for the car you were going to put it in and then gotten an Into OEM Radio replacement harness for the 93 radio. That would have solved your problem and you would have not needed to cut any wires. I've seen a guy wire in a BMW radio in a ford using that method (it worked too. Go figure!)
Here is the Pin out diagram for dodge radios (the one on top is for yours)
Duane...
If you think you're confused, imagine how you feel.   Wiring Info for 93 Caravan Cassette Deck - Last Post -- posted image.
