2004 BMW 5 Series Remote Starter
Autoobsession
Copper - Posts: 119
Posted: May 11, 2004 at 9:51 PM / IP Logged
I am pretty sure this cant be done but am curious if anyone has attempted to install a remote start/alarm in this car. Appreciate any feedback on this.
profuse007
Gold - Posts: 2,015
Posted: May 12, 2004 at 1:04 AM / IP Logged
hmmm.... badass ride. i would love to work on one of these.
sorry yo, no info......
try to look at some of the previous models or others models to see any pattern or resemblance. hows the key like? all the other series use 555b...... try it. let it be the guinea pig and post some result.
Houston,TX
Autoobsession
Copper - Posts: 119
Posted: May 12, 2004 at 7:24 PM / IP Logged
I am not even gonna bother. This car is very much like the new 7 series and from what I have heard from BMW technicians neither of them can be messed with.
profuse007
Gold - Posts: 2,015
Posted: May 13, 2004 at 1:53 AM / IP Logged
have BMW use laser key yet?
i havent done any BMW, but why are they do hard?
whats behind it?
Houston,TX
tjdurham
Copper - Posts: 180
Posted: May 13, 2004 at 1:53 PM / IP Logged
 its not that they are hard there is not much info on these cars so its not like a GM where most wires have been the same for 30 years every model bmw is different and if something goes wrong how about $125 per hour to diagnose so its not worth it to most shops to work on them
tj
jfk51502003
Copper - Posts: 221
Posted: May 13, 2004 at 4:09 PM / IP Logged
THIS IS A 2002......
DIRECTWIRE™ WIRING INFORMATION - BMW / 5 SERIES / 2002 / Remote Start
[PRINT THIS PAGE]
12volts red  +  ignition harness
Starter BLACK / YELLOW  +  ignition harness
Second Starter
Ignition green (x3)  +  ignition harness
Second Ignition purple  +  ignition harness
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock blue/red  +  door module in driver door
Power Unlock BLACK/ white  +  door module in driver door
Notes: Unlock requires a double pulse.
Lock Motor
Unlock Motor
Parking Lights+
Parking Lights- black    headlight switch
Notes: Cutting this wire turns on the parking lights. Use a relay to interrupt the wire to flash the parking lights. See DirectFax document 1055 for wiring information.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blue/red  +  dome light
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white  -  trunk pin
Hood Pin
Trunk/Hatch Release gray/black  -  release switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black  ac  round diagnostic plug under hood
Wait to start
Brake Wire BROWN / gray  +  brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
2004 BMW 5 Series Remote Starter - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: EWS IIIPart #: 555B
Notes: See DirectFax document 1056 for additional wiring information.
profuse007
Gold - Posts: 2,015
Posted: May 13, 2004 at 10:21 PM / IP Logged
are you saying this from experience or just hearing it from another installer? or are you just saying this cause its an expensive car?
Houston,TX
