Remote start will no longer work
Sick64inLB
Posted: May 19, 2004 at 11:45 AM / IP Logged
I have a sidewinder 7000esp on my 1996 chevy s-10 and the remote start work all until I put my MSD 6AL  ingnition box on, can anyone please help me!?!
idbl_fanatic
Member - Posts: 23
Posted: May 19, 2004 at 11:50 AM / IP Logged
While you were messing under the hood, is it possible that you bent the pin switch?? I know mine will not start if any door or hood is open
Sick64inLB
Posted: May 19, 2004 at 12:01 PM / IP Logged
no  I dont have one, I wonder if I have to connect the wire going to my coil to the tach terminal on the MSD box. I'm gonna go try that, i'll let u guys know
Platinum - Posts: 12,488
Posted: May 19, 2004 at 12:29 PM / IP Logged
The MSD will screw up your tach signal that the remote starter requires. What you have to do is to reprogram the tach signal and see if this will help.
kgerry
Platinum - Posts: 3,455
Posted: May 19, 2004 at 12:40 PM / IP Logged
and for g*d sakes put a pin switch under the hood to prevent accidental starting....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Power Stroke
Member - Posts: 10
Posted: May 19, 2004 at 4:57 PM / IP Logged
as soon as a neighbor stops by to "unpin" him from the back side of his garage :)
Sick64inLB
Posted: May 20, 2004 at 8:17 AM / IP Logged
Well the problem was that I had to hook the tach wire that was originally going to the neg. on the coil to the tach terminal on the MSD 6al box. Thanks for the the help though guys!
