speaker bushings
stormshadow
Member - Posts: 34
Posted: May 22, 2004 at 4:51 PM / IP Logged
Hi,
I am installing a set of 5.25" and 6.5" Alpine speakers. I spent most of the day running arround looking for spacers. I have a 95 Geo Prism LSI. I finally found a set for the 6.5" speakers but no one has the 5.25" X 1" available.
I was thinking of useing hard rubber bushings, instead of the Metra spacer. I was wondering if anyone had done this, or could forsee any problems with this method?
I prefer not to have to buy a sheet of MDF and go through makeing spacers if the bushings would work. I would appreciate any feedback/advice.
Thank you.
Stormshadow
Alpine Guy
Platinum - Posts: 2,478
Posted: May 22, 2004 at 5:38 PM / IP Logged
grab anything you can cut into a circle, , corner of your desk,  many layers of cardboard.
italnpimp59
Silver - Posts: 427
Posted: May 22, 2004 at 6:47 PM / IP Logged
yea you dont have to buy something made for it, just get creative.  i sometimes use masonite board, its cheap and easy to cut.
stormshadow
Member - Posts: 34
Posted: May 23, 2004 at 11:35 AM / IP Logged
Thanks for the advice. I found some old MDF. I am going to cut it into spacers. I noticed that the OEM, plastic pannel adapter was angled up, I could accomplish this pretty easily with my router. Do you think angling the speakers up is worth it or doesn't it really matter, I can rotate the tweeter up 15 deg anyway.
Thank you,
Stormshadow
customsuburb
Gold - Posts: 1,813
Posted: May 23, 2004 at 4:21 PM / IP Logged
You should the speaker upwards if it is low in the door panel. This will improve your imaging.
stormshadow
Member - Posts: 34
Posted: June 05, 2004 at 8:29 AM / IP Logged
Thank's for all the help guys.speaker bushings - Last Post -- posted image. Sorry about the late reply, but I have been working 24/7.
I made the spacers out of MDF, but I ran out of room on the door pannel. I have decided to make my own kick pannel mounts, out of glass. I am used to using epoxy resin, but I was looking at the Vinyl Ester Resin or Polyester Resin. Can anyone tell me if the Vinyl Ester Resin needs wax to surface coat, or does it behave more like a epoxy resin?
Thanks,
Stormshadow
