Problems with OEM 97 Acura CL 2.2 Alarm
uiskibum
Posted: May 24, 2004 at 1:21 PM / IP Logged
I have a small problem.  Whenever I lock the car via the remote the Security Door Lock Fuse (Under the hood #38 15amp) blows.  It only happens when I use the remote and not when I lock the car with the key or bye the power door lock switch.  I'm running out of 15 amp fuses!
Has this happened to anyone else, and does anyone have any ideas what is causing this?
Thanks guys!
kenmci
Copper - Posts: 161
Posted: May 24, 2004 at 2:04 PM / IP Logged
It's not blowing when you use the door lock switch because it is a different source.  It could be a short within the oem alarm itself.  Best bet is to look up were the factory alarm brain is and see if any of the wires have been shorted out.  If all else fails and nothing looks wrong there may be an internal short in the alarm brain and honda will have to replace/repair it.
