stereo install on a 2004 scion?
sexyvic1
Copper - Posts: 144
Posted: May 29, 2004 at 2:15 AM / IP Logged
my friend just bought a 2004 scion and we are planning on doing a system. he has the one that is kind of like a truck. not the car. just curious if anybody has experiance with this vehicle and if you have any tips, or if u ran into any problems. i never worked on one yet so any feedback and info helps.
Ketel22
Silver - Posts: 976
Posted: May 29, 2004 at 2:50 AM / IP Logged
ive never seen the "Car" in person but it is the Xb
Quad L Handyman services
jfk51502003
Copper - Posts: 221
Posted: May 29, 2004 at 11:49 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SCION / XB / 2004 / Remote Start
[PRINT THIS PAGE]
12voltsWHITE/ blue and WHITE/ red + ignition harness
Starterblack + ignition harness
Second StarterN/A
Ignitionblack + ignition harness
Second IgnitionBLACK / YELLOW + ignition harness
Third IgnitionN/A
Accessoryblue/red + ignition harness
Second AccessoryN/A
Keysenseyellow - ignition harness
Power Lockblue/white - driver kick, 14 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlockyellow/black - driver kick, 14 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motorblue/orange 5widriver kick, 9 pin plug
Unlock MotorYELLOW /GREEN 5widriver kick, 9 pin plug
Parking Lights+green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights-N/A
HazardsGREEN/ orange - hazard switch
Turn Signal(L)GREEN/ black + top of fuse box, 13 pin plug
Turn Signal(R)GREEN/ YELLOW + top of fuse box, 13 pin plug
Reverse LightRED / black + top of fuse box, 9 pin plug
Door TriggerRED / white - top of fuse box, 9 pin plug
Dome Supervisionuse door trigger wire
Trunk/Hatch Pincommon with door trigger
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm ArmN/A
Factory Alarm DisarmN/A
Disarm No UnlockN/A
Tachometerblack ac data link connector, pin 9
Notes: The data link connector is below the fuse box.
Wait to startN/A
Brake WireGREEN/ red + brake pedal switch
Parking Brakeblack - parking brake switch
Horn TriggerWHITE/ red - steering column
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
stereo install on a 2004 scion? - Last Post -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
