remote control of amps
robblackman
Member - Posts: 22
Posted: May 31, 2004 at 4:17 PM / IP Logged
hi
my head unit does not remote control my amp how do i switch my amp on/off
thanks in advance
rob
live42day
Member - Posts: 26
Posted: May 31, 2004 at 4:20 PM / IP Logged
Your head unit only controls turning the amp on and off when the head unit is powered on or off. Wire a switch in between the amp turn on wire so you can control it manually.
robblackman
Member - Posts: 22
Posted: May 31, 2004 at 4:31 PM / IP Logged
hi
is there another way other than a manual switch that i might forget to switch off
cheers
rob
DYohn
Platinum - Posts: 10,741
Posted: May 31, 2004 at 4:36 PM / IP Logged
Use the remote on signal lead from your head to the remote on input of the amp.   It's usually a blue wire.
forbidden
Platinum - Posts: 5,354
Posted: May 31, 2004 at 5:07 PM / IP Logged
or blue/ white. If it is a factory head unit then you will have to use the ignition wire.
robblackman
Member - Posts: 22
Posted: May 31, 2004 at 6:10 PM / IP Logged
cheers once again
