Ford F150 vs. Autopage RS750 Door Locks Problem!
martystre
Posted: September 04, 2002 at 8:38 AM / IP Logged
I am having problems installing the "remote door locks"in the Ford F150. It does not have keyless entry or auxilliary remote button.
Can anyone out there help me with this? I have everythingelse hooked up except for this and it is driving me crazy!
So any help would be appreciated!
Please respond to: brandy143@hiroad.net
joyride2k
Member - Posts: 40
Posted: September 04, 2002 at 4:01 PM / IP Logged
What year? If it's the newer style, it will be 5 wire positive.
Wires are located above parking brake bracket, along with you door/dome sense wire, in a bundle of about 15 wires going across the dash:
pink / YELLOW = lock
pink/green = unlock
You're going to need two relays wired up as follows:
Relay 1 (lock)
85 - green off of module
86 - 12V+ constant
87 - 12V+ constant
87a - SWITCH side of pink / YELLOW
30 - MOTOR side of pink / YELLOW
Relay 2 (unlock)
85 - blue off of module
86 - 12V+ constant
87 - 12V+ constant
87a - SWITCH side of pink/green
30 - MOTOR side of pink/green
Good luck.
