Mustang and Clifford Alarm, 451m problem
milenko
Member - Posts: 14
Posted: June 04, 2004 at 5:11 PM / IP Logged
Alright guys, I started the alarm install for my clifford matrix 2.5
I started on the 451m and the doors, connected ALL the wires it came with, the Mustang has a 5 wire system.
I connected the 5 wires to the wires according to: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1995-97&make=Ford&model=Mustang&ID=17831&type=Alarm
Once this was all connected, I pressed the interior lock/unlock, one worked, and when I pressed the other (forget which) the lights dimmed and I could smell burning.
I opened the 451 and saw that two strips were cooked, but it still may work..what happened and why?
draasch
Gold - Posts: 2,172
Posted: June 04, 2004 at 6:00 PM / IP Logged
well lets atrt with the year of mustang.....did it have factory keyless????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
milenko
Member - Posts: 14
Posted: June 04, 2004 at 6:10 PM / IP Logged
1996 Mustang GT
No, the car did not come with factory keyless.
sroth140
Silver - Posts: 513
Posted: June 05, 2004 at 12:45 AM / IP Logged
grab two new relays, check your wiring, and try again.
MECP certified installer
milenko
Member - Posts: 14
Posted: June 05, 2004 at 8:08 AM / IP Logged
How can I get a replacement 451m?
I'm not a dealer, would I just go back to the place I bought the alarm?
How much do you think a replacement 451m costs?
draasch
Gold - Posts: 2,172
Posted: June 05, 2004 at 9:14 AM / IP Logged
what are the outputs on your alarm for the door locks?????
can you post the wiring info??
Good Luck
David
Ace Security
813-376-9778
Tampa
milenko
Member - Posts: 14
Posted: June 05, 2004 at 9:35 AM / IP Logged
The outputs are as follows:
Purple - power +12v
Brown - neutral? (says forum post somewhere on this board)
White - neutral? (says forum post somewhere on this board)
Green - unlock +
Blue - lock +
milenko
Member - Posts: 14
Posted: June 05, 2004 at 9:36 AM / IP Logged
Also, the inline fuse to the 451m didn't blow, but the module smells like it's fried...I'll post a picture soon
milenko
Member - Posts: 14
Posted: June 05, 2004 at 9:52 AM / IP Logged
Here are the pics:
1. I  think the fried 451m
[img]http://umass.servebeer.com/images/alarm/1.jpg[/img]
2. My wiring
[img]http://umass.servebeer.com/images/alarm/2.jpg[/img]
milenko
Member - Posts: 14
Posted: June 05, 2004 at 9:53 AM / IP Logged
Looks as if you can't post pics that way:
Mustang and Clifford Alarm, 451m problem - Last Post -- posted image.
