1997 bmw 318i tips?
mainormoscoso
Member - Posts: 41
Posted: June 08, 2004 at 12:00 AM / IP Logged
  Does any body has installed a remote start/alarm in this car I would like to know if it has a transponder and any tips that might have to do the installation easier. thanks
kgerry
Platinum - Posts: 3,455
Posted: June 08, 2004 at 9:40 AM / IP Logged
yes it has a transponder... you need to use a 555B or equivalent
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Autoobsession
Copper - Posts: 119
Posted: June 08, 2004 at 7:03 PM / IP Logged
12volts RED / wht or red   +  ignition harness
Starter blk/yel or grn/blk   +  ignition harness
Second Starter
Ignition green   +  ignition harness
Second Ignition pur/wht or purple   +  ignition harness
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock WHITE/ red   +  factory alarm plug
Notes: The alarm plug is a black 12 pin plug located just behind the glove box. It is mounted with the pins facing you atop a vent just to the left of the body computer. Other wires at the alarm plug are: 12V- RED / white; Accessory- PURPLE / white; Siren- BLACK/ blue; Ground- BROWN / orange. Do not use the power sources at the alarm plug to operate high-current devices. The other side of the siren wire is mounted in a 2 pin plug at the passenger rear corner of the engine compartment. The other wire in the plug is a brown ground wire. DEI recommends attaching the siren at this point.
Power Unlock blue/red   +  factory alarm plug
Lock Motor
Unlock Motor
Parking Lights+ gry/pur, gry/yel    headlight switch
Notes: These wires are the separate left and right parking light wires. Use both wires and isolate each.
Parking Lights- blue/green (hazards)    factory alarm plug
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger    -  factory alarm plug
Door triggers are BROWN / gray for the drivers front door, BROWN / blue for the passenger front door, and BROWN / white for the rear doors (if equipped). Use all three wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white   -  factory alarm plug
Hood Pin PURPLE / green   -
Notes: Located in a single pin connector next to the factory alarm plug.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Notes: If equipped with a factory alarm, the alarm will be plugged into the factory alarm plug. The only way to arm and disarm the factory alarm is with the factory remote. If your planning on using the 8360 pre-wired alarm harness the factory alarm must absent or removed.
Disarm No Unlock
Tachometer black  AC  instrument cluster
Notes: The wire is located in a white connector behind the instrument cluster. Do not unplug the white connector with the ignition on or turn the ignition on with the plug disconnected.
Wait to start
Brake Wire blue/red   +  at brake pedal switch
Parking Brake
Horn Trigger BROWN / red   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
1997 bmw 318i tips? - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: EWS IIPart #: 555B
Notes: See DirectFax document 1056 for additional wiring information.
