crossover for 2 amps
raptor333
Member - Posts: 46
Posted: June 19, 2004 at 12:23 PM / IP Logged
Hi I was wondring if anybody could help me decide on what kind of crossover would be best if I wanted to connnect 2 sony xplode amps together and possibly another amp for other speakers?
DYohn
Platinum - Posts: 10,741
Posted: June 19, 2004 at 1:28 PM / IP Logged
What are you using the amps for?  This will determine what kind of crossover you need.
jeffchilcott
Platinum - Posts: 2,483
Posted: June 19, 2004 at 1:40 PM / IP Logged
if you are going to run 2 or more amps you should consider getting an in dash eq
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
raptor333
Member - Posts: 46
Posted: June 19, 2004 at 11:00 PM / IP Logged
I am using the amps to run  2 12inch subs
DYohn
Posted: June 20, 2004 at 9:30 AM / IP Logged
So if you're running both amps for your subs, you'll need a subwoofer crossover (or use the LP crossover on the amps.)  If you run another amp for your mains, you'll need to run it off a high-pass crossover (or use the HPF on the amp.)  Is this what you want, or are you looking for brand name recomendations?
raptor333
Member - Posts: 46
Posted: June 20, 2004 at 10:27 AM / IP Logged
that is perfect, but do you have any brand name recomendatons?
DYohn
Posted: June 20, 2004 at 11:05 AM / IP Logged
How much do you want to spend?
raptor333
Member - Posts: 46
Posted: June 20, 2004 at 7:33 PM / IP Logged
Ok, I looked at my amps and I understand the lp crossover for my subs what kind of amp do you think i should get for my mains ($200). Can i run my midbass drivers and front speakers from this amp and my tweeters from my head unit?
