autostart/ alarm help please
Thatricerdaniel
Posted: June 19, 2004 at 11:47 PM / IP Logged
having some problems locating the correct wire for the auto start. according to the12volt.com it is one of the two white wires in the steering column however they are not the correct wires. The car is a 95 240. can someone please point me in the right direction.
what I am looking for is the ignition wire to actually start the car. I am at a point where the car will crank but will not start because the ignition wires i have are the one that lose voltage on crank. i need the one that gets voltage on crank. thanks !
Sorry im a newbie and If i wasent clear on anything please be patient.
tjdurham
Copper - Posts: 180
Posted: June 20, 2004 at 12:30 AM / IP Logged
main ignition is white\blue
starter black\yellow
did you test the wires to see if one of them stays on during crank if it stays on thats your true ignition there should only be one
tj
