86 camaro stereo
FearMyAfro
Posted: June 21, 2004 at 1:21 AM / IP Logged
I just installed my Pioneer head unit in my 86 camaro but i have no idea where to put the illumination and dimmer wires that were attached to the old stereo. I am completely new to this and any help would be greatly appreciated. thanks
jugga-nemo
Copper - Posts: 81
Posted: June 21, 2004 at 8:51 AM / IP Logged
On a lot of older cars, the stock decks didn't require those wires, so you have to just tap into others. The dimmer wire usually taps into your dash light switch, (so that when you dim your dash lights, the deck dims with them). This wire is not necessary. The illumination wire can either be tapped into the accessory in your ignition harness under the stearing column or most people tap the cig lighter as that usually turns on with the accessory also.
5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
kgerry
Platinum - Posts: 3,455
Posted: June 21, 2004 at 10:21 AM / IP Logged
in that car illumination was a grey wire and dimmer was a brown wire at the radio....meter them for verification.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sparkie
Platinum - Posts: 2,061
Posted: June 21, 2004 at 3:47 PM / IP Logged
If your Pioneer radio has an illumination wire connect it to the grey wire for the car's dash illumination. It will facilitate the dimming of any lamps inside your Pioneer radio. If it doesn't have any illumination wire DON'T hook it to any other wires. Tape the wires up so they don't short circuit and blow a fuse.
sparky
