92 vw cabriolet, viper 300, turbo timer
mikeboone
Member - Posts: 13
Posted: June 28, 2004 at 2:49 PM / IP Logged
i plan on putting a viper 300 in my wifes 92 cabby this weekend. my question is that i need to install a turbo timer also.  i need a 12volt, ON and ACC for the turbo timer, but the car only has 12v, starter and ignition. what to do, im having a brain fart. also if it goes to the ignition it goes on the starter side of the starter kill correct?  one more question, i am putting hella air horns on it, and want them to sound with the siren, whats the best way to hook them up?
thanks mike
swamprat323
Gold - Posts: 1,335
Posted: June 29, 2004 at 5:37 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|RED / black           |+ |ignition harness            |
|        IGNITION|black               |+ |ignition harness            |
|        ACCESSORY|BLACK / YELLOW        |+ |ignition harness            |
|       POWER LOCK|                    |   |                            |
|     POWER UNLOCK|                    |   |                            |
| PARKING LIGHTS +|gray or gray/green |   |light switch               |
|       HEADLIGHTS|WHITE/ black        |+ |light switch *1             |
|     DOOR TRIGGER|BROWN / white        |- |either pin switch           |
| TRUNK/HATCH PIN|BROWN / white        |- |at switch or light *3       |
|       TACHOMETER|green               |   |ignition coil               |
|       BRAKE WIRE|RED / black           |+ |brake switch               |
|     HORN TRIGGER|BROWN / blue          |- |steering column             |
|           WIPERS|green (low) *2      |+ |steering column             |
Notes:
*1 The wire runs between the light switch and high/low beam selector. *2 A GREEN/ YELLOW works with the (high) speed position. *3 Grounded at rest through park light switch. Add diode to gray/green wire (band towards light) to prevent reading ground at switch.
May be a dumb question-- what is a turbo timer?
mikeboone
Member - Posts: 13
Posted: June 29, 2004 at 6:20 PM / IP Logged
turbo timer lets the car run after the car is shut down to let the turbo cool
draasch
Gold - Posts: 2,172
Posted: June 29, 2004 at 6:36 PM / IP Logged
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK IGNITION SWITCH HARNESS
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Accessory BROWN / RED IGNITION SWITCH HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mikeboone
Member - Posts: 13
Posted: June 29, 2004 at 7:06 PM / IP Logged
are you sure BROWN / red is acc, oh well ill just test it when i tear in to the car
swamprat323
Gold - Posts: 1,335
Posted: June 29, 2004 at 7:41 PM / IP Logged
On the omega disk3 it says BROWN / red nut on dei techsoft ist say it BLACK / YELLOW. As with all the wire guides soem info is not correct. Lets us know what colors it is so I can make a note on it.
